It is currently Fri Feb 28, 2025 12:42 am
 Post subject: Styrofoam Caul?
PostPosted: Wed Jul 22, 2009 8:22 am
I was HHG gluing some .050" ebony veneer to the inside of the upper bout for a sound port backing and was thinking of a quick way to make a clamping caul for it. I remembered back to my Discus fish breeding days when I used styrofoam under the aquariums to level them out from uneven surfaces. So I bent the veneer on the Ibex and I glued a piece of Styrofoam to a piece of wood and clamped it up. Perhaps this might come in handy for some other things. I understand this might not work in a situation where a lot of pressure is needed for a long time because the foam will compress and conform to the shape and may loose the clamping pressure. But it seems to work in this case.
 Post subject: Re: Styrofoam Caul?
PostPosted: Wed Jul 22, 2009 8:27 am
After one hour the strofoam conformed to the shape but it was long enought to let the glue set and hold. But I wonder if this might have possibilities for making contour sanding blocks? Some food for thought and something to play around with I guess.
PostPosted: Wed Jul 22, 2009 8:32 am
Works great, that's how I do my soundport reinforcements. They can be shaped but, like you, I leave 'em a little flatter to be sure and get the edges down good.
Wes McMillian
Santo, TX
http://www.wesmcmillian.com
PostPosted: Wed Jul 22, 2009 8:40 am
The fact that it conformed to the shape I thought was the advantage of not needing to shape it. I just cut a 2" piece in half on the bandsaw and didn't really shape it any. I think it looks that way because i clamped it once before I took the picture of it. But it's nice to see that great minds think alike. :D
PostPosted: Wed Jul 22, 2009 8:55 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
I have been using styro cauls for decades for sanding blocks, they are really fast for making a profile as in any shape moulding. I now use them in guitar work when sanding areas like the sides at the waste and at the neck heel.
Mike McNerney
Mike McNerney
PostPosted: Wed Jul 22, 2009 9:02 am
I have seen some relatively dense and strong styrofoam. The carpet cleaner used blocks of this to set the furnature legs on until the rug dried.
In the first article I read years ago on vacuum clamping bridges, the method included making exact fitting styrofoam cauls with a two-part mix that generated the styrofoam.
PostPosted: Wed Jul 22, 2009 9:03 am
Well, am I at least the first one to post this tip on the forum? :P
PostPosted: Wed Jul 22, 2009 9:05 am
City: Lawrence
Zip/Postal Code: 66047
I use the styrofoam blocks the carpet cleaners put under the legs of your furniture.
It's a little more dense and It's better than just throwing them away.
PostPosted: Wed Jul 22, 2009 9:56 am
Yeah,same here . I like using these for sanding blocks too.
PostPosted: Wed Jul 22, 2009 10:09 am
I'm guessing that to make a contour shape from a dense piece of styrofoam you can attach sandpaper to the contour and sand the shape into the foam?
